3D Design
3D Design
how can i edit/modify the geometry?
    • luster
      i made a line using sketch->equation. after pressing the esc, what do i do if i want to modify the line?
    • Keyur Kanade
      you can use undo to go back or you can modify it using split edge option or other options.
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      moving to geometry and cad category.
      Keyur
