March 2, 2022 at 5:44 pm
vivekparimi
SubscriberIn a simulation that I am running, I am exciting the metal structure using a current source. Some part of the current leaks to the lossy substrate. While I am able to see the leakage current, is there a way to know the exact impedance of the metal path and the substrate path?
March 28, 2022 at 11:58 amPraneeth
Please provide more information about your model to help us serve you better.
Can you name the type of model that you are trying to simulate like microstrip line, strip line, co planar waveguide etc. ?
Or else you can share snapshots of your model indicating the model geometries and the excitation type using the upload image provided with the post.
All the very best Praneeth.
March 28, 2022 at 3:10 pmViewing 2 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceTrending discussions- simulation completed with execution error on server
- Maxwell, HFSS or Q3D?
- Error
2600
2088
1319
1108
459
