Ansys Free Student Software
Topics cover installation and configuration of our free student products
How can I fix ” C:\Users\david\AppData\Local\Temp\AnsysWBDumpFile.dmp “?
    • mcpattydaddy
      Hello, I've been trying to incorporate a mesh into a elbow pipe in Ansys fluent. I'll create the geometry and generate the shape, but when I click on mesh it says an error occurred and that it's in C:UsersdavidAppDataLocalTempAnsysWBDumpFile.dmp . I've read the other forums that solve this issue for other people, but non of them have worked for me. I changed the nvidia to higher graphics, I added the dll's, I tried to redownload it, and I've redone the geometry dozens of times.
      Any tips on how to help? I'd really like to figure this out so I don't have to run it through citrix...
    • ANSYS_MMadore
      Have you tried renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old where vXXX is the version you're running? Does this only happen with that one project?
    • mcpattydaddy
      I did try that, and it still popped up with the same error. I've also tried different projects and the same message pops up, some in fluent and others in static structural.
    • mcpattydaddy
      I have the dump file copied to my desktop, it won't allow me to place it here. It's encrypted, but I can send it to someone on the support team to see what it says and maybe that will provide an answer to why it's giving me such problems.
    • ANSYS_MMadore
      Please open a Windows command prompt and run the command "set" and return the full output.
    • mcpattydaddy
      C:\Users\david>set
      ADSK_CLM_WPAD_PROXY_CHECK=FALSE
      ALLUSERSPROFILE=C:\ProgramData
      ANSYS211_DIR=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\ANSYS
      ANSYS_SYSDIR=winx64
      APPDATA=C:\Users\david\AppData\Roaming
      AWP_LOCALE211=en-us
      AWP_ROOT211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211
      CADOE_LIBDIR211=C:\Users\david\Desktop\ANSYS\ANSYS Inc\ANSYS Student\v211\CommonFiles\Language\en-us
      CommonProgramFiles=C:\Program Files\Common Files
      CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
      CommonProgramW6432=C:\Program Files\Common Files
      COMPUTERNAME=DESKTOP-LRHAV4F
      ComSpec=C:\WINDOWS\system32\cmd.exe
      DriverData=C:\Windows\System32\Drivers\DriverData
      HOMEDRIVE=C:
      HOMEPATH=\Users\david
      LOCALAPPDATA=C:\Users\david\AppData\Local
      LOGONSERVER=\\DESKTOP-LRHAV4F
      LSTC_LICENSE=ANSYS
      NUMBER_OF_PROCESSORS=8
      OMP_NUM_THREADS=8
      OneDrive=C:\Users\david\OneDrive
      OneDriveConsumer=C:\Users\david\OneDrive
      OS=Windows_NT
      Path=C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\WINDOWS;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;%SYSTEMROOT%\System32\WindowsPowerShell\v1.0\;%SYSTEMROOT%\System32\OpenSSH\;C:\Program Files\MATLAB\bin;C:\Users\david\AppData\Local\Microsoft\WindowsApps;
      PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
      PROCESSOR_ARCHITECTURE=AMD64
      PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 9, GenuineIntel
      PROCESSOR_LEVEL=6
      PROCESSOR_REVISION=9e09
      ProgramData=C:\ProgramData
      PROMPT=$P$G
      PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
      PUBLIC=C:\Users\Public
      SESSIONNAME=Console
      SystemDrive=C:
      SystemRoot=C:\WINDOWS
      TEMP=C:\Users\david\AppData\Local\Temp
      TMP=C:\Users\david\AppData\Local\Temp
      USERDOMAIN=DESKTOP-LRHAV4F
      USERDOMAIN_ROAMINGPROFILE=DESKTOP-LRHAV4F
      USERNAME=david
      USERPROFILE=C:\Users\david
      windir=C:\WINDOWS
    • ANSYS_MMadore
      Please run dxdiag from a Windows command prompt and send the full output.
Viewing 6 reply threads
