How can i get a tangent modulus?
    • zzang3132
      Hi. I study mechanical engineering.
      I’m trying to analysis nonlinear structure.
      I have a yield strength and tensile strength value.
      But, when i use bilinear, i need a tangent modulus.
      how can i get the tangent modulus?
      is there a equation or formula?
      please share your skill and information.
    • peteroznewman
      Set the Tangent Modulus to 0.0 for a conservative analysis.
      Once you use Plasticity in the material model, you need to know another material property: Elongation (at Break).
      Elongation is the value of Strain when failure occurs in a simple tensile test.
      Without Plasticity, you may have used Ultimate Tensile Strength to calculate a Safety Factor for the design.
      With Plasticity, and a zero Tangent Modulus, the stress will not go above Yield, so you need a new Safety Factor.
      Safety Factor = Elongation/(Equivalent Total Strain)
      A Safety Factor < 1.0 predicts failure.
