March 25, 2021 at 3:41 pm
YounusMandalawi
SubscriberI used the code provided here https://support.lumerical.com/hc/en-us/articles/360034383114-Creating-a-custom-source-time-signal-for-an-FDTD-source to get two gaussian pulses as below.
March 25, 2021 at 9:00 pmKyle
Ansys EmployeenTo use this signal you will have to somehow change lines 17 and 18 to create a vector that corresponds to your time signal. I don't think there are any built-in functions to create the type of signal you're interested in, unless you can use mathematical functions like the double Gaussian pulse example. Alternatively, if you have the data for the signal in a text file you could import the data with the readdata command:nnMarch 26, 2021 at 2:38 pmMarch 26, 2021 at 2:49 pmMarch 26, 2021 at 4:26 pmKyle
Ansys EmployeeThis will depend on the polarization of the source, not the time signal. If you have a plane wave polarized in the z direction the x and y components of the electric field will be zero.nViewing 4 reply threads- You must be logged in to reply to this topic.
Ansys Innovation SpaceSimulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Error on Lumerical device
- Lumerical support has moved to the Ansys Learning Forum (ALF)
- focusing efficiency
- How to perform optimization over terminal in linux without GUI?
649
612
220
196
128
Top Rated Tags© 2022 Copyright ANSYS, Inc. All rights reserved.
