How can I get displacements, stresses and plastic strains at the integration points for a shell mode
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeDisplacements are not available at integration points as a list. We display "pseudo" displacements at the expanded element shape plot (see /ESHAPE). 1. At the top/bot/mid locations integration points are in the RST file and can be accessed through regular post-processing commands (see OUTRES command, KEYOPT(8)). 2. Element results can be output at all integration points in the printout (OUTPR,ESOL command). Please note that the element results may be extrapolated from in-plane integration locations to nodal locations before being stored into RST file. Use the ERESX command if you want the original integration point results.
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- What is cause of error: display time for result item greater than the step end time?
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- Can you limit the expansion of modes to only those modes with a high participation factors by using
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
5432
3391
2473
1310
1022
