April 15, 2022 at 3:38 pm
MadScientist
SubscriberHello,
I have the STEP geometry of an airfoil imported into Spaceclaim and I projected the foil normally on a sketch plane to get the airfoil profile, made of splines. Now I want the XY position of the points generating these profiles. For an earlier airfoil, it was more segmented, so I could get the start and end points through this snippet
curves = Selection.Create(Curve23, Curve24, Curve25, Curve26) for item in curves.Items: x = item.Shape.EndPoint.X * 10 z = item.Shape.EndPoint.Z * 10 if(x > maxXPos): maxXPos = x if(z > maxZPos): maxZPos = z if(i == 1): x = item.Shape.StartPoint.X * 10 z = item.Shape.StartPoint.Z * 10 if(x > maxXPos): maxXPos = x if(z > maxZPos): maxZPos = z i=i+1
But now, these curves are actually Splines, and using the above, I get only 5 points defining the airfoil. So I wanted to know the member functions or variables that will allow me to get intermediate points in a Spline. The image of the foil is as below.
April 29, 2022 at 1:34 pmAniket
Forum Moderatoryou can find knots on a spline using the following code:
curve_knots = myC.Shape.Geometry.Data.Knots
for p in curve_knots:
result = Point.Create(*list(myC.Evaluate(p.Parameter).Point.Vector))
result = SketchPoint.Create(result)
-Aniket
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8806
4658
3151
1680
1470
