March 11, 2020 at 7:00 am
March 11, 2020 at 10:33 am
Gaurav Sharma
SubscriberHi KKC
Discovery Live follows no slip boundary condition by default. Hence, the particle velocity at any surface is equal to the velocity of surface itself. When you try to extract velocity at any stationary surface, it is expected to give zero value as result.
I tried the chart option to measure velocity on a surface in a sample model where, I applied Swirl on the surface. As expected, the velocity output I got was equal to the velocity of the surface.
I hope that explains the reason behind your observation. Please let me know if there is any further confusion.
Best Regards,
Gaurav
March 12, 2020 at 3:03 am
March 12, 2020 at 3:06 am
March 12, 2020 at 6:57 am
Gaurav Sharma
SubscriberKKC
I could reproduce your observation. Prima facie, it seems results with 2019R3 were incorrect and necessary changes are made in 2020R1 so that no slip conditions are appropriately respected. However, I am confirming this internally and will get back to you with final response soon.
Best Regards,
Gaurav
March 12, 2020 at 7:30 am
skikuchi
SubscriberHello Grarav,
Thank you for your reply.
I' ll wait for you final answer.
Shoichi
March 12, 2020 at 10:53 am
Gaurav Sharma
SubscriberHi Shoichi,
I got the confirmation that my understanding was correct. The results with 2019R3 are incorrect and not to e referred. With the corrections incorporated in recent release, 2020R1 gives you correct results. It is also justified that the velocity values at stationary surface is zero, due to no slip condition.
Thanks & Regards,
Gaurav
March 13, 2020 at 4:19 am
skikuchi
Thank you for your investigation.
I understand that it has been incorrect till 2019 R3 and has fixed from 2020 R1.
Thank & Regards,
Shoichi
3694
2564
1765
1234
590
