Ansys Products
Ansys Products
How can I get ‘paramagnetic.cpp’ and ‘paramagnetic.h’ in lumerical?
    • xudong Zhang
      I want to write a plugin based on the 'paramagnetic ' in material plugin in lumerical,but I can't find the file about it , which is mentioned in the webset(Advanced and custom optical material models in FDTD and MODE – Ansys Optics). Can someone help me download the 'paramagnetic.cpp' and  'paramagnetic.h'?
    • Guilin Sun
      If you have registered, you can log in the webiste to get the file.
      If you have not registered, plase register.
      • xudong Zhang
        Thank you for your kindly help! I have registered before ,but I can log in the webiste recently.I will try it again.
    • Guilin Sun
      Please check your log in. If you still cannot see the example files, you may need to register again since recently there are some changes, and it is supposed to have support qualification.
      • xudong Zhang
        I have re-registered a new account, thanks again for your help!
