October 20, 2021 at 3:06 am
idrees
SubscriberI need to perform a vee bending simulation on Aluminium alloy 3003-0 in Ansys transient structural. But i am facing difficulty how to get data points for defining multilinear isotropic hardening in engineeing data Ansys.Please any one guide me.
October 20, 2021 at 11:05 amVinayak Vipradas
Ansys EmployeeMultilinear Isotropic Hardening is defined by Plastic Strain vs True Stress, where the first point indicates the onset of Plastic Deformation which is (0, yield strength). The first point in the table is at zero plastic strain and stress at the yield point. The stress-strain curve should be monotonically increasing so the negative slope of stress-strain data should be discarded." target="blank">Defining a Multilinear Plasticity Hardening Model in Ansys Mechanical - YouTube
For a detailed explanation on data points for defining Multilinear Hardening, please refer to this link:
Thank you,
Vinayak
October 20, 2021 at 11:20 amidrees
SubscriberThanks for the response.
Sir I have already watched the video you referred me,I also know the concept of putting the first input as (0,yield stress) but I do not know how to get other data points from the the above stress strain curve,especially how to get the stress values.
October 20, 2021 at 4:06 pmVinayak Vipradas
Ansys Employee,
I assume your model is based on the data from the Stress-Strain curve image that you have provided. If not, you can google 'Stress-Strain Curve for Aluminium alloy 3003-0' and find the required data. You need to select a sufficient number of data points in the plastic region of the curve, where the intercept of the Strain axis in the Plastic region gives Plastic Strain and the intercept of the Stress axis gives Stress coordinate. You may also need to convert data in engineering Stress and Strain to True Stress and Strain.
Does that answer your question?
Thank you Vinayak.
October 20, 2021 at 5:14 pmidrees
SubscriberSir you mean I can take any arbitrary data points in the plastic region?
My second question is ,by defining the Isotropic elasticity is it OK I just put the values of Young's modulus and Poisson ratio ? Or for that I still need a table of data points
such as for the Multilinear isotropic hardening?
Thank You!
October 21, 2021 at 7:39 amVinayak Vipradas
Yes, you can take arbitrary data points in the plastic region but make sure these points represent a monotonically increasing curve till the point of necking and these points should be scattered within this range.
For the second question, if your analysis is concerned with isotropic material and the temperature range is within the limit, you only need to provide one set of values of Young's Modulus and Poisson's Ratio for defining Isotropic Elasticity.
Thank you Vinayak
October 21, 2021 at 7:58 amidrees
SubscriberThank You sir!
October 21, 2021 at 8:01 amVinayak Vipradas
Ansys EmployeeYou're welcome. Best of luck!
Vinayak
November 4, 2021 at 7:16 pmidrees
SubscriberSir i have watched the Ansys learning video about Defining a Multilinear Plasticity Hardening Model in Ansys Mechanical many times but I am really not able how to get the stress strain data points table from the given graph for AA 3003-0.Sir plaese show me a way how to solve this problem,I am really stuck with my Thesis!!!
January 1, 2022 at 5:32 pmViewing 9 reply threads- You must be logged in to reply to this topic.
Trending discussions- How can i get stress-strain data points for defining Multilinear isotropic hardening in Ansys
- Reynolds Number in Fully Developed Turbulent Flow
- Opening course files using ANSYS 19.1
- Error: WorkBench Error: Could not handle event: SolutionStatusUpdate Error Object: #f
- Formula SAE Composite Monocoque Chassis Analysis – Geometry File
- Mesh fail
- Coriolis Flowmeter 2 way FSI workshop files
- Turbulent flow
- Ansys innvoation course files
- How to get the Ansys Course Completion: Intro to Python Badge
2656
2120
1345
1118
461
