how can i get the temperature of node?
    • lvxk
      Hello,teachers,firstly thank u so much for your answer。 i am using GRid motion to control the interface of soild and fluid with a special temperature,so i need to compute the nodes' temperature and then if the temperature is low,the node will move at the solid direction,when the temperature of node is high,the node will move at the fluid direction.but the condition of node moving is the temperature of node,i am using the "F_T"function solved the temperature of adjacent central face,and i am plan to use it to solve the node value,THe quesion is how can i get the temperature of node,whether Fluent UDF has difference or deviation function using face temperature solving the node value,surely i find the uDF manual,there is not have the function directly get the node temperature but position。
Viewing 0 reply threads
