December 17, 2022 at 4:55 pm
Mustafa Kiracoglu
SubscriberHi,
Is there any option that I can give my 2d or 3d object a mass? Or should I run something different to see air flow on my object?
December 17, 2022 at 8:44 pm
SubscriberPlease describe what you are trying to simulate with a lot more details. Insert an image or a sketch to help explain it. Why do you want to see the air flow on the object? What is it that you want to calculate in the simulation? Why do you need mass on the objects?
The usual way to have a 2D or 3D object have mass in a simulation is for the material to be given the Physical Property of Density. Then the analysis will compute the mass from the volume of the object.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
