How can I identify if a fluid is Non-Newtonian?
    • prajput
    • Keyur Kanade
      Hi @prajput ,
      When the rate of deformation (shear rate) in a fluid is not directly proportional to the applied shear stress, you have a non-Newtonian fluid.
      Depending on the behavior exhibited by the fluid, they can be categorized as one of the following types of non-Newtonian fluids - Bingham plastic, Pseudoplastic, and Dilatant.
    • prajput
      Thank you for the quick reply @kkanade ! Can you give me some examples of non-Newtonian fluids?
    • Keyur Kanade
      Ketchup is a good example. That is why you need to shake it well to let if flow. Also creams and shampoos are non-Newtonian fluids. Even the lipstick!
Viewing 3 reply threads
