August 21, 2019 at 2:13 pm
Hoosein86
SubscriberHello,
I want to define a non linear Material in ANSYS , (not plastic!), but It has to have almost stiffness like steel and have a nonlinear behavior.
where can I find Material Properties in Plastic part of Hooke's Law and how can I insert in ANSYS Engeeniring Data?
I really be appreciated if you give me some information about this Issue.
August 21, 2019 at 2:20 pm
SubscriberPlease elaborate on the nature of the non linear behavior of this material.
Hooke's Law defines the linear portion of the material and is implemented in Engineering Data under the Linear Elastic category and is typically Isotropic Elasticity which requires the Young's Modulus and Poisson's Ratio. If you use a similar value of Young's Modulus to steel, then you will have similar stiffness as steel.
August 24, 2019 at 6:40 am
Hoosein86
SubscriberThanks for your answer.
How can I find non linear Material Properties value?
August 24, 2019 at 2:47 pm
SubscriberDo you mean hyperelastic? You have to say what kind of non-linear behavior you want.
August 28, 2019 at 4:17 pm
Hoosein86
SubscriberHow many non-linear behavior we have?
I just know Hyperelastic
August 28, 2019 at 7:00 pm
SubscriberA lot. Expand all the categories in the Engineering Data toolbox, they are nearly all non-linear.
June 19, 2020 at 8:20 pm
McKivitz
SubscriberI too am trying to apply a non-linear behavior to a steel component that has been heat treated(carburized) giving it a much higher yield strength. Is there anything in the ED toolbox that I'm missing short of creating a stress strain curve? thanks.
June 22, 2020 at 9:37 pm
SaiD
Ansys EmployeeHi,
You could use the Structural Steel material from the Engineering Data toolbox and change the value of the Yield Strength manually. But this would only give the behavior till the Yield Stress. If you want to simulate the behavior beyond that point, you would need to add and define some type of Plasticity behavior. Biliear Hardening only requires an additional Tangent Stiffness Modulus, as opposed to data for an entire stress-strain curve.
Hope this helps,
Sai
2104
1327
1110
461
