April 21, 2021 at 8:31 pm
Chris Kopetski
Ansys EmployeeWe have an existing Chi3 Raman Kerr model that may allow you to set the imaginary part of Chi3. This may not be trivial for all cases since you will need to come up with a combination of the parameters (alpha, w_raman, delta_raman, etc) to construct the imaginary part.
Question migrated from the Lumerical Knowledge Exchange.
- Error on Lumerical device
2616
2098
1321
1108
461
