February 23, 2022 at 11:25 am
yeje2007
SubscriberHello all.
I made a cold storage model and then I have to analysis a interior temperature.
I think, I should find it by transient thermal
but I can't insert a inlet velocity and temperature
This is my boundary conditions
Inlet -> velocity: 4 m/s, temperature: 278 K
wall -> Convection-> free stream temperature: 298 K, Heat Transfer Coefficient:0.027 W/(m^2 K)
Interior Temperature: 298 K
Please Help me. Thank you.
February 23, 2022 at 11:36 amRob
Ansys EmployeeIn CFD we'd model the flow part (and thermal) or calculate an external HTC and provide that along with the external free stream temperature.
I suspect Mechanical does the same. So, the velocity of 4 m/s will be accounted for in your derived HTC, if it's been done correctly.
February 26, 2022 at 5:40 amyeje2007
SubscriberTank you for the reply
but I can't understand
I want to know how can I see the node's temperature (function in CFD)
I want to analysis of the interior temperature but I don't know what to click .
Please help me.
Thank you so much
March 1, 2022 at 11:34 amRob
Ansys EmployeeSurface temperatures, or point values can be found in the Results section of Fluent (that's in the solver not the Workbench interface). If you're not sure what to do click on "Help" and do some of the tutorials and/or watch some of the courses at the top of the page.
Trending discussions- Limitations to Student License?
- ANSYS License Manager Error
- Problem with ANSYS 18.2 SpaceClaim
2656
2120
1347
1118
461
