February 21, 2022 at 1:44 pm
naftali.herscovici
SubscriberHello,
I need to be able to kill the HFSS process if the "oDesktop.QuitApplication" does not do it for various reasons
I tried "tskill ansysedt.exe" but it did not find the process
Any ideas?
March 7, 2022 at 5:46 pmPraneeth
You are using the right command.
Please check whether you are implementing correctly in the work flow.
All the very best Praneeth.
- Maxwell, HFSS or Q3D?
- Error
2614
2088
1321
1108
459
