April 29, 2022 at 9:03 am
sara_01
SubscriberHi everyone!
I try to explain my problem.
On APDL I have a volumetric mesh consisting of 9 parts and all these parts have elements of the 'mesh200' type. I want to convert 'mesh200' to 'Solid187'. To do this conversion i used these commands:
Preprocessor --> Element Type --> ADD Element --> Solid 10 node 187
nsel,all
emodif,all,type,10
esel,all
emid,add,all
In the APDL window the commands have been executed and has not reported me errors, but the mesh has not changed. So I would like to know if there is a way to understand if the conversion has taken place.
Thanks to those who will answer!
April 29, 2022 at 4:24 pmRahul Kumbhar
Ansys EmployeeThe script should be something as below
fini
/prep7
et, 100, 187 ! define element type 187
esel, s, ename, , 200! select elements of Mesh200
emodif, all, type, 100! reclassify elements 200 as 187
esel, s, ename, 187! select elements of name 187
emid, add, all! add mid side nodes to selected elements
fini
April 30, 2022 at 8:09 amsara_01
SubscriberI've tried and now it works. Thank you very much for helping!
May 2, 2022 at 4:06 amRahul Kumbhar
Ansys EmployeePlease mark as answer if it has resolved your query so that it would be helpful to others too.
Trending discussions- check element type
- Error in meshing
- Meshing Error
- How to resolve Mesh Failure
- How to get three elements across the wall thickness of a thin part
- Meaning of the symbol crossed out tick mark on a body in the tree outline indicate in Meshing
8786
4658
3151
1678
1468
