October 28, 2018 at 10:52 pm
hgsdvd
SubscriberHello guys,
I made an enclosure in Design Modeler and considered it as a room. Now, I got stuck on how to draw the door and windows in this enclosure. I have used cut material, add frozen, and other commands, but none of these went well.
Could anyone help on how to draw these openings to let the air in and out while modeling?
I am modeling fire inside this room so that I need the air(Oxygen) inside the room to develop the fire growth.
Thanks,
Muha -
October 29, 2018 at 6:49 am
Keyur Kanade
Ansys EmployeeHi,
Please have a look at following video.It may help you in creating holes.
Keyur
Also, please like the answers which have helped you move forward and in the end, once your issue is resolved, please mark the most appropriate solution (most useful advice) as 'Is Solution'. This will help others who are using this thread to find answers to similar questions.
October 29, 2018 at 8:14 pm
October 30, 2018 at 3:37 am
Keyur Kanade
Ansys EmployeePlease use Fill option. It will delete that face and fill it with material.
July 18, 2020 at 12:54 pm
CFDisGreat
SubscriberKKanade,
Do you know how to make multiple holes on a curved surface in DEsignModeler?
Thank You
July 18, 2020 at 2:24 pm
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2080
1299
1106
459
