February 18, 2021 at 3:49 am
far29
SubscriberHello, I am trying to model snoring related vibrations using the frequency dependent material for my arterial wall. I have a graph of pressure ratio versus frequency that represents the vibrations that I want to model on ansys. Any way I can do that using the material properties or do I need to use a different approach n -
February 19, 2021 at 8:45 am
1shan
Ansys Employee,nThere are several methods to curve fit response data of a vibration test ( pressure vs frequency in your case) and find out the damping ratios at each natural frequency for example https://www.mathworks.com/matlabcentral/answers/373890-rational-fraction-polynomial-for-modal-parameters-extraction. You could use these damping ratios and insert them as material properties (the way I told you in our previous discussion https://forum.ansys.com/discussion/comment/106529#Comment_106529) and perform a harmonic analysis.nRegards,nIshan.n -
March 7, 2021 at 5:08 am
far29
SubscribernThank you for your answer. nany way I can do that for Prony series in transient analysis. If so can you explain the way to do so nThanksn
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5278
3299
2469
