How can I model Foam Pads I am using as Spring elements.
    • UTKARSH PATEL
      Foam Pads are installed inside a box with no gaps to its adjacent sides.
    • Ashish Khemka
      Forum Moderator
      Do you want to assign properties of foam to spring? Also, can you share a snapshot of the problem that you want to model?
      Ashish Khemka
    • UTKARSH PATEL
      Hi Ashish,
      Yes, I want to assign foam properties to a spring. I have a Foam (shown in black). Its installed in a box (shown in red). there is no gap between the box and the foam. all sides they are touching. this is a top view that is shown below.
      a right side view, shows the same foam being pressed down by a cover. so the cover will press onto the foam. i am trying to model this foam as a spring.
