How can I model heat transfer from hot fluid to cold solid?
    • sevgia
    • sevgia
      It looks like solid is always 26 C degree but fluid gets colder. I need to see the thermal change on solid. I'm also adding how I define the temperature values in next screenshot.
      Because you changed the wall between the fluid and solid to a temperature from coupled the wall will always be 26.85C. You need to use coupled and patch the solid temperature into the system.
    • sevgia
      This time, I follow this steps. It it what you recommend? Thank you
    • sevgia
      I finished analysis. But the problem is, places where water is not filled looks like 90 C ( 363 K). How can I fix it?
      How long did you run the model for?
    • sevgia
      It was around 300 number of steps with 0.001 step size
      OK, so you've modelled 0.3s of hot water hitting the mug. Replot the temperature contour just on the mug using the local temperature.
    • sevgia
      Thanks a lot. It worked when I change global to local. But at the start of the simulation I see some different colors inside solid.
      What could be leading this? Is there a way to fix this look? When I run the simulation more, it looks normal like this;
      Look at the scale in the first image - you're picking up noise so altering the scale to 298.0 - 298.2 should fix it. The second image is more normal as you have a 10K temperature range.
    • sevgia
      When I choose local option, scale changes automaticly depending on the time. When I choose global, I can't see temperature change of solid glass. Is there a way of arranging this?
      There should be a manual or user defined range. I tend to post process in Fluent so am not entirely sure what the option is called.
    • sevgia
      Thank you
Viewing 12 reply threads
