May 4, 2023 at 6:25 pm
Merve Ala
SubscriberI make an analysis by using the time-step method for four days. But for the out file, some data are missing. I checked the file name and its true.And I have update case&data file. How can I write to out file from calculated data? I run again the analyze but it doesn't still update out-file. What can I do?
May 4, 2023 at 6:53 pm
Hasan İlker ÇELİKER
SubscriberMerve Hanım merhaba,
Ne üzerine bir çalışma yapıyorsunuz?
May 4, 2023 at 7:46 pm
Merve Ala
SubscriberThanks for answering, (I will write in English for all users), I am working on a wind turbine beam, and I got that graph during calculation. But I realized that the out file didn't save after a few seconds during calculation. I still have update case&data file but I can not reach that graph again.
Türkçe olarak biraz daha açmam gerekirse, out dosyasının kayıt yolunu kontrol ettim ve bir yanlışlık görmedim. Ama nasıl olduysa koşturmaya başladıktan kısa bir süre sonra noktaları kaydetmemiş. Tekrar run dedim ama grafikleri out dosyasına yazdırdığı değerler üzerinden yapıyor. Arka planda hesaplanmış değeri nasıl tekrar yükleyebilirim? Bir yolu olmalı diye düşünüyorum
May 5, 2023 at 8:42 am
Ansys EmployeeThe graph looks like a monitor, and you’d usually set to save data to file when you create the plot. In Fluent the above is “just” an image, the saved data is in text format. If you run one time step when the solver updates the plot you may get some of the above graph back.
Thanks for keeping the thread in English. Whilst I work with the team in Turkey, it's one (of many) languages I don't speak. My French team leader isn't entirely convinced I speak English.....
5290
3311
2471
