TAGGED: angular-velocity, dynamic-mesh, fluent, rotational
February 20, 2023 at 2:55 pm
Milne Ando
SubscriberG'day,
in dynamic mesh zones panel, we can get the moving object's angular velocity and angular displacement (angle), but I also need the data of its angular acceleration. Does anyone know how to get that?
Hope someone can tell me. Thank you.
February 20, 2023 at 4:13 pm
Ansys EmployeeI suspect you'll need previous time step velocity data and then work it out based on the time step size.
February 20, 2023 at 5:30 pm
Milne Ando
Subscriberit sounds like I need to import the six DOF file into matlab or Excel, and do some commands to get angular acceleration, right?
February 21, 2023 at 9:48 am
Ansys EmployeeI suspect so. The surface forces and velocity are available, acceleration is a little more complex as it's the change in velocity. If you're using a UDF check for previous time step values, but note not all data is available.
3744
2573
1821
1236
596
