June 3, 2020 at 4:47 am
SHALINI
SubscriberHello everyone,
I want to plot vorticity contour to visualize the blade tip vortices of NREL phase VI wind turbine blade. I tried to plot velocity curl contour on the plane generated behind the blade at tip but this was not successful. Could someone please help me regarding to plot vorticity contour.
I will be very grateful.
June 9, 2020 at 12:27 pm
Karthik R
AdministratorPlease use the Custom Field Functions in Fluent to plot vorticity. You should be able to choose the first derivatives as input fields.
Define -> Custom Field Functions
From the drop-down, please pick 'Derivatives' and select 'dY-Velocity/dx'. Hit 'Select'. Add the '-' (minus) sign and then pick the other derivative 'dX-Velocity/dy'. This would be the definition in 2D. If you are running a 3D simulation, please create the function using the appropriate definition and you should be able to plot a contour using these Custom Field Functions.
I hope this helps.
Thanks.
Karthik
3862
2639
1859
1254
600
