Ansys Free Student Software
How can I properly link Visual Studio with ANSYS Fluent, to load in UDFs
    • LarsH
      I am using Ansys 2019 R3 and Visual Studio 2017. I have always gotten the nmake not found error so I changed some environment variables to fix this and it kind of worked, but now I get the following error, when building libudf from Fluent (opened from Workbench):n********************************************************************************************************************************************************n** WARNING: Automatically switched to run in parallel -t1 mode. **n** Detected non-parallelized UDF usage, enabling parallel usage. **n** If you encounter any issues, please re-run with -t0 flag. **n****************************************************************************n****************************************************************************udf_names.c and user_nt.udf files in 2ddp_node are upto date.n(system copy \Program Files\ANSYS Inc\ANSYS Student\v195\fluent\fluent19.5.0\src\udf\makefile_nt.udf E:\Daten\Uni\Masterarbeit\Ansys\Stroemungsrohr\Stroemungsrohr_files\dp0\FFF\Fluent\libudf\win64\2ddp_node\makefile )n1 Datei(en) kopiert.n(chdir E:\Daten\Uni\Masterarbeit\Ansys\Stroemungsrohr\Stroemungsrohr_files\dp0\FFF\Fluent\libudf)(chdir win64\2ddp_node)# Generating ud_io1.hnmyUDF.cnD:\Program Files\ANSYS Inc\ANSYS Student\v195\fluent\fluent19.5.0\src\main\global.h(9): fatal error C1083: Datei (Include) kann nicht ge�ffnet werden: stdio.h:No such file or directorynnI have seen that the knowledge based solution #2049257 is often recommended, but I can't access it because it is only accessible through the customer service portal.nCan somebody help me with this, please?n
    • ANSYS_MMadore
      Please try installing Visual Studio 2017 with these options.nThanks,nMattn
