Photonics
Photonics
How can I read out the exported material data file (.mdf)
    • SunnyECNU
      Hi, I have recently exported the database of the material's index, and the file format is .mdf. I wonder whether or not I could use matlab to read the data out and how? If not which one I should use to reach out to the data.
    • Kyle
      The MDF files are used to transfer material databases between Lumerical simulation files. They can be imported by the Material Database using the "Import Material File" button:
      I don't think there is a way to read them out in another program. If you want to access the material data, you can do so with the getmaterial command in a script.
