3D Design
3D Design
How Can I read Spaceclaim Script from Workbench Script?
    • Li1003
      I am trying to read Spaceclaim script through Workbench Script to get a geometry, the Workbench Script is shown as follow,
      # Open Geometry
      geometry1 = system1.GetContainer(ComponentName="Geometry")
      geometry1.Edit(IsSpaceClaimGeometry=True)
      # Close Geometry
      geometry1.Exit()
      What should I put after geometry1.Edit(IsSpaceClaimGeometry=True) ?
      Thank you.
    • Keyur Kanade
      Please post the questions in appropriate category. Moving this question to other category to get better response.
      Moving to geometry and cad category.
    • Li1003
      Thank you, sir. Do you know how could I solve this problem?
    • Aniket
      Li1003, I am sorry, this question is out of support scope of student community as the sending commands from workbench journal is not documented (It is possible but not documented currently, so does not fall under support scope)
      -Aniket
Viewing 3 reply threads
