June 22, 2020 at 4:48 pm
Sorte
SubscriberI'm trying to validate some wind tunnel simulations. My geometry consists in 5 spires at the entrance of the wind tunnel, and various roughness elements (square blocks) at the surface of the wind tunnel. I attach the print of my geometry.
I have already tested different methods and sizes of the elements, but I could only achieve this: skewness Min 1.31E-10, Max 0.99842, Average 0.21809. The orthogonal quality is Min 1.58E-03, Max 0.99999 and Average 0.78044.
How can I reduce my skewness?
Thanks -
June 23, 2020 at 4:13 am
Keyur Kanade
Ansys Employeeif you are going to use fluent, please check orthogonal quality. if min ortho quality is greater than 0.1 then your mesh is good.
please find the locations of bad elements. please check following video.
then apply different sizing at those locations. in some cases you may need to modify geometry at those locations.
Keyur
June 23, 2020 at 4:14 pm
Sorte
SubscriberThank you Keyur for your answer. Yes, I will use Fluent.
The orthogonal quality of this mesh is Min 1.58E-03, Max 0.99999 and Average 0.78044. What do you think about this?
I identified that the spires are the ones that present the bad elements, as you can see below.
How can I apply different sizes in these specific locations?
If that doesn’t solve the issue, I can try to modify the geometry in these locations, as you suggested, but I am not sure how to do that as well…
Thanks, Sorte
June 24, 2020 at 2:32 am
Keyur Kanade
Ansys Employeebest way is to modify geometry.
if you want to change sizing, please see below.
Keyur
June 24, 2020 at 10:16 am
Sorte
SubscriberThank you for your reply. How can I modify the geometry?
I am very new to this software, and I am trying to learn it in any possible way. Thank you in advance.
June 24, 2020 at 10:35 am
Ansys EmployeeGo back to the Geometry tool. It will probably help if you do the tutorials that come with the Help function.
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3930
2641
1861
1272
610
