August 1, 2019 at 8:53 am
Azim07
SubscriberHello Guys,
I want to define the specific heat and viscosity of the material by following UDF and it is showing 'Floating Exception Error'. How can i Fix this? And what kind of precautions i should take to avoid any further Error?
and can it be fixed by reducing time step size? I used 0.5 and 0.1
#include "udf.h"
DEFINE_SPECIFIC_HEAT(cp_pcm,T)
real cp;
if (T<303)
cp=1250;
else if (T>=303 && T<=304)
cp=125000;
else
cp=1250;
return cp;
Azim07
SubscriberDEFINE_PROPERTY (cell_viscosity1,c,t)
real mu;
real temp = C_T(c,t);
if(temp<303)
mu=100000000;
else if (temp>304)
mu=0.008;
else
mu =(15200000000-(50000000*temp));
return mu;
August 1, 2019 at 11:03 am
Ansys EmployeeHow about using ONE thread to hold all your linked questions? Otherwise I'll just start locking the new ones.
If you set a constant value in the model with the above values does it work? You did read the bit about UDFs using SI units?
2706
2142
1355
1144
462
