How can I run several times a simulation with an array of Parameters
    • eduardo_hulse
      I'm working on a simulation on APDL and I have to run the same test with different values of diameter and wall thickness for a pipe. I have the values saved on a txt file, but don't know how to do these multiples tests, only with one pair as shown:
      *DIM,parametros,array,2,1
      *VREAD,parametros(1,1),auxiliartest,txt
      (E14.8)
      T11 = parametros(1)
      T22 = parametros(2)
      Any thoughts on how to do it, and how to write and export those results in different text files
      thanks in advance!
      ps: I have atached an example of a file that contains different pair of parameters
    • Ashish Khemka
      nnPlease see if the following link helps:nnnRegards,nAshish Khemka
