July 11, 2018 at 9:32 am
Sebastian
SubscriberHello,
I set up an transient Co-Simulation between Maxwell and Simplorer. Is it possible to couple the transient thermal simulation in Simplorer too? How is it possible to set up the Sub--circuit?
Thank you in advance!
August 16, 2018 at 7:56 am
DrAmine
Ansys EmployeeMoving the question in the related physic sub-thead
August 21, 2018 at 2:26 am
KR
AdministratorHello,
Could you please elaborate on what you're attempting to model? This might help us provide you with some guidance here.
Best,
Karthik
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2961
1449
1322
