March 11, 2021 at 11:07 am
dzungleanh
SubscriberMarch 11, 2021 at 2:38 pmAndyJP
Subscriberwhat about the solder? solder is a conductor. if you know the impedance, use lumped at blue arrow. if you think that the skinned coax has lost its impedance, use a coax pigtail and a wave port.nMarch 12, 2021 at 4:18 pmPraneeth
Ansys EmployeenThank you for reaching to us.nKindly confirm what you are looking to design. Please provide more inputs to help us serve you better.nBest Regards,nViewing 2 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
2706
2142
1355
1144
462
