HOW CAN I SIMULATE HEAT (TEMPERATURE) CHARACTERISTICS ?
    • mikiluv1
      I want to investigate into how the heat generated in the copper plate of SIW can affect the substrate with respect to time and power (W). I would be glad to get a direction on which pack to use and how to use it. Thank you.
    • Anchal Singh
      You can use Icepak in AEDT to perform an electrothermal analysis.
      You can go through the following lesson to get an idea about setting up the electrothermal analysis. Make sure the thermal properties of the material in HFSS are defined to perform an electrothermal analysis.
      Electrothermal Analysis Using Icepak in Ansys Electronics Desktop ÔÇö Lesson 4 - ANSYS Innovation Courses
      Thank you!
      Anchal
