December 5, 2019 at 7:06 pm
jbuter
SubscriberHello, I do get configurations to work in an assembly. But when I want to use configurations in sub assemblies. I cannot get it to work.
so I want 1 assembly with machines and be able to change the configuration of 1 machine by its own sub assembly.
December 5, 2019 at 9:51 pm
Brian Bueno
Ansys Employeejbuter
In order to modify subassembly configurations, you need to right click the subassembly in the structure tree and select Open Component. Make your configuration changes at this level and then close the component to return to the main assembly.
At the current point in time there is no way to alter the subassembly configuration from the top level assembly UI.
- loss of user settings
- Ansys Discovery Modeler vs Spaceclaim speed
- pressure
- Annotation font color
- Can’t see license on online account
- Copy user settings to new release
- help online
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Python Script: graphical interface
- Unexpected graphics error
5268
3299
2469
