July 20, 2019 at 8:22 pm
Samson
SubscriberHi,
I have a the problem that, when I use Matlap R2019a to run Mechanical APDL it only uses 2 cores.
I already changed the core count to 8, how it is desribed in the link below. The problem is it didn´t change the number of cores Ansys uses when using matlap to run it.
Here is the link I´m talking about: https://forum.ansys.com/forums/topic/configuring-from-2-core-to-4-core-processor-for-ansys-18-2/
I hope somebody has a solution. Thanks
July 22, 2019 at 12:37 am
SubscriberWhat is the command line you are using to run the ansys solver from matlab?
Is it something like this?
/home/ANSYS Inc/v194/ansys/bin/Linux64/ansys194 -b -i input.dat -o solve.out
All you need to do is add the flag -np 8 and it will run on 8 cores.
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3744
2573
1793
1236
594
