How can I use the Froude number to analyze sea waves?
    • Keyur Kanade
    • Karthik R
      Administrator
      Hi @kkanade ,
      For shallow water waves applications, the Froude number is used to define three flow conditions:
      -subcritical (Fr<1), the water velocity < wave velocity, namely downstream conditions affect the upstream flow;
      -critical (Fr=1), the water velocity = wave velocity, upstream waves remain stationary;
      -supercritical (Fr>1), the water velocity > wave velocity, namely upstream flow is not affected by the downstream conditions.
    • Keyur Kanade
      Thank you! @Kremella
      I have another question, Since the Froude number is defined as:
      Fr = V/sqrt(g*L)
      where V is the characteristic velocity, g is the characteristic external field, L is the characteristic length. What should I use for V, g and L?
    • Karthik R
      Administrator
      Hi @kkanade ,
      In your case, V is the average flow velocity, g is the gravitational acceleration and L is the flow depth.
Viewing 3 reply threads
