TAGGED: point-temperature, probe, simulation, thermal
November 26, 2020 at 7:30 am
Hassaan
SubscriberI want to probe at the of thin sheet during thermal analysis. But I have to divide the body. When I divide the body results get changed. Can anyone tell me if I can probe in the mid of a thin sheet without dividing the body. (It only selects corners)nnThanks in advance.nnRegardsn -
November 26, 2020 at 9:09 pm
SubscribernCreate a Coordinate System at the middle of the thin sheet. You can probe at the coordinate system origin.n
- The topic ‘How can we apply temperature probe in thermal analysis in mid of a body?’ is closed to new replies.
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3153
1680
1470
