May 16, 2022 at 4:39 am
ahadr33104
SubscriberI want to inject cylindrical particle in DPM model. Can we inject non spherical particle without shape factor? if I want to inject non spherical particle in a channel how can I do it? thanks in Advance...
May 16, 2022 at 8:41 amRob
Ansys EmployeeYou can't. The DPM model assumes spheres. If you need shape then Ansys Rocky may be a better solution. What are you injecting?
May 17, 2022 at 5:32 pmahadr33104
SubscriberThanks, Sir!
I want to study a single capsule of cylindrical shape conveyed by airflow or we can say the problem is pneumatic conveying of the capsule in a channel ...
May 18, 2022 at 8:37 amRob
Ansys EmployeeWhich breaks most, if not all, of the DPM guidelines. Have a look at the Macro particle model (spheres only) or moving mesh with a load of UDFs for motion and collision avoidance.
May 22, 2022 at 6:46 pmahadr33104
SubscriberSir, I want to inject a cylindrical capsule into piping Chanel and study its flow parameters in the MAcro particle model on spherical particles that can be injected ... dynamic meshing is computationally very expensive.
Can I inject cylindrical particles somehow in the DPM model or MAcro particle Model?
May 22, 2022 at 6:52 pmahadr33104
SubscriberI have Installed Ansys 2021 R2 and rocky 4.4 but I am unable to couple these two because rocky is not showing in the ESSS panel of ansys...
can we couple these two versions or what can be the problem in coupling...
Viewing 5 reply threads- You must be logged in to reply to this topic.
3694
2564
1765
1236
592
