January 24, 2021 at 10:41 pm
Hesam062
SubscriberIn Eulerian transient model with species transport (non-reaction), I want to make two mixture material phases . From model >> species I selected the mixture template for phase 1 but I am confused how I can make another mixture material (for phase 2). Do I have to select a pre defined mixture form species phase property (like benzene -air ) and then modify it (delete species of pre defined mixture and add new desired species). Is there any other straight way like what I did for phase 1?
Thanks for your time.
January 25, 2021 at 1:37 amHesam062
SubscriberThe solution was simple but tricky! It toke one week to find it!!
I have selected the mixture template for all phases in species model. At this time fluent shows just ONE mixture template in material panel. So to create the seconded one I did right click on mixture template and select copy. Then new mixture template created and can be modified.
Always I was looking for NEW command to create mixture like what we do to create/add new material. Maybe ANSYS would change it this way sometime.
January 25, 2021 at 7:37 amDrAmine
Ansys EmployeeHi Hesam, nice suggestion I will request it.
5162
3275
2453
