Preprocessing
Preprocessing
How could I mesh this in order to match the nodes between concrete and rebar?
    • javiarredondo
      I believe Ansys 2020 consider the joint work of both elements automatically without the need of the matching points in mesh but I think it would help the simulation to run better (correct me if I am wrong).
      I am modelling a 9 meters long reinforced concrete pole, with a conic hollow section as you can see.
      Any help is welcome.
      I am using Multizone for Meshing, it gives a great mesh but I can´t make it match with the reinforcement position, I was trying to use a Sizing method.
    • javiarredondo
      I am trying to make it like this, modifying the bias factor till I get it. I still dont know how to make the simmetrical 20° degree mesh n
