August 14, 2018 at 8:45 pm
José Mantovani
SubscriberHello everyone!
So, here I have a convergent-divergent tube type, like a "venturi" and I want generate a structured mesh but I'm use academic package and I don't have ICEM CFD. I need a small height in the cells near wall, for this I try to use inflation layers but when I make this I get a unstructured mesh. If my domain were 2D I would use edges to imprint size controls, but as the domain is 3D I don't know how is the best/easy way to do this.
Someone have some tips about it?
Thanks for helping,
Mantovani.
August 14, 2018 at 9:43 pm
Karthik R
AdministratorHi Mantovani,
Have you looked at this tutorial on Youtube.
Best Regards,
Karthik
August 15, 2018 at 1:33 pm
José Mantovani
SubscriberSo Kremella, thanks, but in my academic package haven't ICEM CFD. I need know how do that using Ansys Meshing.
Thanks,
Mantovani.
August 16, 2018 at 12:29 am
klu
Ansys EmployeeHi Jose,
Can you please try to use the Multizone plus inflation as shown in the video below?
August 16, 2018 at 2:11 am
Karthik R
AdministratorHello Jose,
I apologize, I did not read your question properly. I thought you were looking for a way to use ICEM CFD for getting your mesh. Please follow klu's advice and use Multizone to create your mesh. It is always a good practice to select the source and target faces for Multizone.
Thank you.
Best Regards,
Karthik
August 16, 2018 at 8:05 am
DrAmine
Ansys EmployeeTry multizone with dedicated source and target as Kremella highlighted,
August 16, 2018 at 3:29 pm
José Mantovani
SubscriberStay fresh Kremella... Very thanks guys, I will try to make this.
Best Regards,
Mantovani.
August 16, 2018 at 5:07 pm
José Mantovani
SubscriberSo guys, by the video shared by Klu I tried and I get this mesh, in the images below with some informations. I use a big number of inflation layers in order to get all circle section with structured mesh, but in the center I get some bad cells... Someone Can help me improve this mesh? With some tips...
Really thanks to all!
Best Regards,
Mantovani.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
459
