February 3, 2021 at 3:26 am
dhruvdeshwal17
SubscriberIn 3D transient analysis (element SOLID97 of node n -
February 4, 2021 at 11:27 am
Navya C
Ansys EmployeeHi,nPlease elaborate on what you are trying to model.nWhat do you mean by equivalent to two step loading?nProvide some screenshots for us to understand and interpret correctly what you are trying to simulate.nnRegardsnNavyan -
February 7, 2021 at 2:52 am
dhruvdeshwal17
SubscriberThanks for your response. Section 2 and 3.1 explain about model and analysis carried out respectively.nhttps://www.researchgate.net/publication/306133315_Design_and_Damping_Analysis_of_a_New_Eddy_Current_Damper_for_Aerospace_ApplicationsYours Sincerely n
- Maxwell, HFSS or Q3D?
- Error
5386
3375
2471
1310
1022
