March 17, 2021 at 10:40 pm
prakhars962
SubscriberFollowing is a strip footing that may be idealized as a plane strain problem.
March 17, 2021 at 10:47 pmpeteroznewman
SubscriberNodes on the right edge have X = 0.Nodes on the bottom edge have Y = 0.nThe node in the corner has both X and Y = 0. nWhere is the conflict?.March 18, 2021 at 1:56 pmprakhars962
SubscriberI was wondering if I can apply BCs by selecting the edges.nHowever, if I'll apply BCs by selecting node then I've to reselect nodes for my BCs as I change my mesh.March 18, 2021 at 4:20 pmpeteroznewman
SubscribernYes, you can apply the BC to the geometry edge, which has the benefit of automatically applying to nodes from any mesh update.nMarch 18, 2021 at 4:53 pmMarch 18, 2021 at 7:55 pmMarch 18, 2021 at 8:01 pmprakhars962
SubscriberI am using 2021 R1 with solid analysis toolboxes not the academic. Can you share the file? So that I can figure out my mistake.nMarch 18, 2021 at 9:18 pmprakhars962
SubscriberThanks a lot. I saw your figure, and found that there was a problem with my geometry. I used edge split and its working fine now. Thanks a lotnViewing 7 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
459
