November 15, 2018 at 2:49 pm
giovanni_ianziti
Subscriberhello,
I`ve a closed volume (heat pipe) with inside a part of water liquid and another part of mixture: air and vapour (when the water is boiling).
In my simulation I don`t have a good representation of the convection. the results are similar to the symmetric case but I`m working with a planar case.
how can I improve the convective movement inside the volume?
thank you
November 15, 2018 at 3:47 pm
DrAmine
Ansys Employee1/Work with compressible liquid for liquid and ideal gas for mixture
2/Apply gravity and set an operating density
3/More details of your case are really welcome so that we can point to some modifications: detailed screenshot of the problem.
As ANSYS Stuff we won't download or check any attached document.
November 16, 2018 at 10:18 am
Ansys EmployeeJust to add, I don't think compressible liquid has a temperature term for density (check documentation) so if the system has a reasonable gas volume use a polynomial for liquid density.
November 16, 2018 at 11:30 am
November 16, 2018 at 11:42 am
Ansys EmployeeIn a confined space you'll need to use an ideal gas: if the density within the system changes but the volume cannot the solver will struggle. If you have openings then it's not a problem.
However, as you've set water with a constant density you won't see any motion in the water due to natural convection within the water.
November 16, 2018 at 2:12 pm
giovanni_ianziti
SubscriberIn my work I have a non-compressible condition to respect for the flow. Can I lose this condition If I use ideal gas for the mixture?
November 16, 2018 at 2:15 pm
Ansys EmployeeYes. As it's a sealed system something must compress as the mass has to go somewhere.
2564
2068
1289
1106
459
