December 11, 2022 at 11:45 am
Ivan Mendez
SubscriberHey all.
I have a set of x,y,z coordinates of cells written in a txt file along with a heat generation rate [w/m3] of each cell. I want to import these data into fluent. What are the ways I can do that? thanks
December 11, 2022 at 2:49 pm
SubscriberHey Ivan,
I don't know for sure since I am a Structural expert, not a Fluent expert, but you can try the following.
Drag an External Data component from the sidebar of Workbench and drop it on the Setup cell of Fluent. Components are below the list of analysis systems in the sidebar. Edit the external data and select the text file.
Hope that works.
Regards, Peter
December 13, 2022 at 12:13 pm
Ansys EmployeeOtherwise you will need a UDF to read the data table to then apply it as a source term.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2156
1359
1150
462
