November 19, 2020 at 11:48 am
Andytran2
SubscriberI am trying to co-simulate a pair of coils in Simplorer and am having trouble setting it up. In the picture named "Coils", my version of ANSYS electronics desktop is missing the options of advanced product coupling and a few others that are seen in the picture labelled "missing2", which was taken from an online tutorial. Also, when i try to implement the coil design into Simplorer, I do not have the option of "add dynamic inductance" in my version of ANSYS which can be seen in "missing", but can be seen when following an online tutorial in "missing3". When I click on any of the options of adding any form of dynamic coupling and choosing my file, I get the following errorĀ message which can be seen in the picture labelled "error".
https://youtu.be/G4RsT6f-iho?t=282 <--- The tutorial associated with "missing3"
November 19, 2020 at 1:41 pmicellb1
Ansys EmployeeHi, ,nWould you mind sharing your screenshots again using upload image rather than upload file since the screenshots are not directly displaying. We are not allowed to click on non-displaying ones. Thank you.nNovember 20, 2020 at 3:01 amNovember 20, 2020 at 3:22 pmicellb1
Ansys EmployeeHi, Array,nThe advanced product coupling option is for transient type solver only. If you didn't use transient for your Maxwell design, that option will not appear in the design settings.nThe name add dynamic inductance was used for old version simplorer, now the name is changed to dynamic magnetostatic.nMake sure you assign matrix under parameters tab in Maxwell in order to avoid that error when linking Maxwell magnetostatic to simplorer.nNovember 20, 2020 at 7:06 pmAndytran2
SubscriberThank you so much!nViewing 4 reply threads- The topic ‘How do I add a Maxwell 3D sub circuit into Simplorer?’ is closed to new replies.
Computational Fluid Dynamics (CFD) helps engineers design products in which the flow of fluid components is a significant challenge. These different use cases often require large complex models to solve on a traditional workstation. Click here to join this event to learn how to leverage Ansys Fluids on the cloud, thanks to Ansys Gateway powered by AWS.Ā
Earth Rescue ā An Ansys Online Series
Trending discussions- Applying rotor skew
- Effect of region on force calculation
- How to make the available GPU on my Desktop to be used for direct solver simulations in ANSYS HFSS ?
- Parasolid entity check failed for part
- HFSS Parasolid Error
- Induction Heating Simulation
- Co-simulation between HFSS and structural/workbench
- IBIS AMI models
- Radial and Tangential force
- example files
8808
4658
3151
1680
1470
