December 2, 2022 at 6:13 am
Ivan Mendez
SubscriberHey all, I want to create a UDF where I'll be reading from a sql database, so I need to find a way to get sqlite to work in ansys. I did #include sqlite3.h in my source file and then compiled them in ansys, but everytime that I do, it asks for a header file. The first header file it asked was windows.h. Once I added that, it wanted me to add winapifamily.h again. And the list goes on. My question is, How do I add a SQLITE header in my udf file without me having to manually go through adding all the necessary headers that sqlite needs?
December 6, 2022 at 1:53 pm
Ansys EmployeeYou'll need all of the headers that SQLITE for the compiler, if they're all in the INCLUDE path it may make things easier. Another option is to pre-screen the data so you don't need to link the UDF to the whole lot: that may reduce the need for the SQLITE bits.
December 8, 2022 at 4:38 am
Ivan Mendez
SubscriberYeah, I just couldn't make it to work so I just gave up and converted the sql database into csv, which makes it significantly easier to process it via udf
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2630
2106
1335
1110
461
