March 13, 2022 at 2:03 pm
Michael_G
SubscriberHi,
I'm working on a Project for my Bachelors (meaning i have limited understanding of stuff) and I need to run a Fluid simulation in Ansys Discovery. The goal of this simulation is to quantify the pressure loss through a 3D Printed (SLM) conformal cooling channel.
Since the surfaces of my cooling channels are printed, their surfaces are extremely course. These course surfaces cause, to my understanding, 2 things: an overall reduction in diameter and affect the turbulent flow inside a channel. The reduction in diameter I could simply design in CAD, but the affects on the turbulent flow are much harder/impossible to quantify.
I could not find anywhere in Ansys Discovery where I could Input my wall surface roughness (and leave the problem to the software to deal with). In Fluent, this is a parameter I found in the following guide: Point 6.10 https://user.engineering.uiowa.edu/~fluids/Posting/Home/CFD/Introductory/Lab%201-Pipe/Introductory_Lab1_Manual.pdf
This leads to my question: How do I simulate the Wall roughness in a channel in Ansys Discovery? Or can i create a link to Fluent, define the boundary condition (wall roughness) and then return to Discovery (button in top right of screenshot below)? Or are both possible?
For reference, I have left a screenshot of one of the channels in quetion below. The diameter of the channels is 5mm.
March 14, 2022 at 1:08 pmNaresh Patre
Surface roughness is currently not available in Discovery. You can transfer the model to Fluent, however it cannot be transferred back to Discovery.
- Naresh Patre
March 15, 2022 at 6:14 amMichael_G
Thank you for the information. It's a shame that surface roughness won't be included in the simulations.
-Michael Griffiths
2656
2120
1349
1118
461
