May 21, 2022 at 7:00 pm
diegocarra
SubscriberI need to demonstrate through Ansys the stresses distribution in a rotating disc. The problem I am facing is when defining the boundary conditions. What boundary conditions should I defined so that the results are the ones you get solving the problem analytically?
Thank you in advance
May 23, 2022 at 11:20 am
Ashish Khemka
If the disc is rotating at a constant speed then you can define rotational velocity. Rotational velocity accounts for the structural effects of a part spinning at a constant rate.
Rotational Velocity (ansys.com)
Regards Ashish Khemka
How to access the ANSYS Online Help ÔÇö Ansys Learning Forum
3812
2593
1849
1244
600
